- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Quite a few forum members have asked for Silverstone PSU's lately, so being kind, I dedicated time to bringing them in.
They are now here
Silverstone Strider 1200W Modular '80 Plus Gold' Power Supply (SST-ST1200-G) @ £144.98 inc VAT
To meet the ever higher requirements imbued by professional users and enthusiasts alike, SilverStone created the Strider Gold series power supplies. The Strider Gold models are built on similar platform as the award-winning Strider Plus series but with even higher efficiency ratings.
The Strider Gold series will encompass wattage range from 750W to 1200W for a great variety of applications. In addition to 80 PLUS Gold level efficiency, all models are built to meet very high standards in electrical performance so they have ±3% voltage regulation, ±3% ripple & noise, and high amperage single +12V rail. Other notable features also included are 24/7 40 degree continuous output capability, Japanese capacitors, low-noise 135mm fan, and multiple sets of PCI-E cables. For users looking for a power supply with faultless combination of performance, efficiency, and quality, there is no need to look beyond the Strider Gold Series.
- 80 PLUS Gold certification with high efficiency 87%~90% at 20%~100% loading
- 100% modular cables
- 1200W (1300W peak power) 24hour fully continuous power output with 40? operating temperature
- Class-leading single +12V rail with 100A
- Strict ±3% voltage regulation and low ripple & noise
- Japanese main capacitors
- Silent running 135mm fan with 19dBA minimum
- Dual EPS 8pin connectors support
- Multiple PCI-E 8pin and PCI-E 6pin connectors support
- Support ATX 12V 2.3 & EPS 12V
- Active PFC
Only £144.98 inc VAT.
ORDER NOW
Silverstone Strider Plus 1000W Modular '80 Plus Silver' Power Supply (SST-ST1000-P) @ £139.99 inc VAT
The Strider series, as the oldest and most versatile power supply line from SilverStone, has models with myriad of innovative features and rating from 350W all the way up to 1500W. To build on this impressive lineup, SilverStone engineered a new generation of power supplies that combine more important features than ever before. The Strider Plus models, ST75F-P, ST85F-P, and ST1000-P are highly efficient (80 PLUS Silver level), compact enough to fit in nearly any system (160mm depth), have tightly regulated performance of ±3% from a single +12V rail design, and equipped with a quiet but cool 135mm fan. To top these features off, the power supplies also come with 100% modular cables with all the important connectors to support current and future graphics card specifications. For enthusiasts that are looking for a power supply with all the right features to make a high performing and aesthetically pleasing system, any one of the Strider Plus models will fulfill the task with maximum satisfaction.
- 1000W 24hour continuous power output with 40 degree operating temperature
- 1100W peak power
- Efficiency 85%~88% at 20%~100% loading
- Class-leading single +12V rail with 80A (peak 85A)
- Four PCI-E 8pin and six PCI-E 6pin connectors support
- Active PFC
- Combined +12V: 960W/80A(Peak 85A)
- Input Voltage: 90V~264V
- Input Frequency Range: 47Hz~63Hz
- Active PFC(PF>0.95 at full load)
- Efficiency: 85%~88%(20% to 100% loading)
- MTBF: 100,000 hours at 25°C, full load
- Operating temperature: 0°C ~ 40°C
- Protection: Over current protection / Over power protection / Over voltage protection / Under voltage protection / Over temperature protection / Short circuit protection / No load protection
- Connectors: 1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 4 x 8/6-Pin PCIE connector(550mm) / 2 x 6-Pin PCIE connector(550mm / 150mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
Only £139.99 inc VAT.
ORDER NOW
Silverstone Strider Plus 850W Modular '80 Plus Silver' Power Supply (SST-ST85F-P) @ £119.99 inc VAT
- 80 PLUS Silver
- 850W 24hour continuous power output with 40?operating temperature
- 950W peak power
- Class-leading single +12V rail with 67A (peak 72A)
- Dual PCI-E 8pin and four PCI-E 6pin connectors support
- Active PFCcombined +12V: 804W/67A(Peak 72A)
- Connectors: 1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 2 x 8/6-Pin PCIE connector(550mm) / 2 x 6-Pin PCIE connector(550mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
- Colour: Black (Lead-Free Paint)
- Cooling System: Silent 135mm fan
- Noise Level: 19dBA-36dBA
- Dimensions: 150 mm (W) x 86 mm (H) x 160 mm (D)
- Weight: 2.9 kg
Only £119.99 inc VAT.
ORDER NOW
Silverstone Strider Plus 750W Modular '80 Plus Silver' Power Supply (ST75F-P) @ £107.99 inc VAT
- 80 PLUS Silver
- 750W 24hour continuous power output with 40?operating temperature
- 800W peak power
- Class-leading single +12V rail with 60A (peak 66A)
- Active PFCcombined +12V: 720W/60A(Peak 66A)
- Weight: 2.9 kg
Only £107.99 inc VAT.
ORDER NOW
Silverstone Strider Plus 600W Modular '80 Plus Bronze' Power Supply (SST-ST60F-P) @ £79.99 inc VAT
The Strider series is the most versatile and time-proven line of power supply products from SilverStone with models rated from 350W to 1500W and packed with innovative features. To build on this impressive lineup, SilverStone engineered a new generation of power supplies that combine more features than ever before.
The Strider Plus ST60F-P boasts the important features professionals and enthusiasts crave:
•High efficiency: 80 PLUS Bronze level
•Compact size (160mm depth) to fit in nearly any system
•Tightly regulated performance of ±3% from a single +12V rail design
•Quiet and cool 135mm fan
The versatility of these power supplies extends to the 100% modular cables with all the important connectors to support current and future graphics card specifications.
For enthusiasts that are looking for the power supply with all the right features to make a high performing and aesthetically pleasing system, the Strider Plus series reaches the goal with maximum satisfaction.
- 80 PLUS Bronze
- 600W 24hour continuous power output with 40 degrees operating temperature
- Efficiency 82%~85% at 20%~100% loading
- Class-leading single +12V rail with 42A
- Single PCI-E 8pin and four PCI-E 6pin connectors support
- Active PFC
- Efficiency: 82%~85%(20% to 100% loading)
- Connectors:1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 1 x 8/6-Pin PCIE connector(550mm) / 3 x 6-Pin PCIE connector(550mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
- Weight: 2.9 kg
Only £79.99 inc VAT.
ORDER NOW
Silverstone Strider Plus 500W Modular '80 Plus Bronze' Power Supply (SST-ST50F-P) @ £64.99 inc VAT
The Strider series is the most versatile and time-proven line of power supply products from SilverStone with models rated from 500W to 1500W and packed with innovative features. To build on this impressive lineup, SilverStone engineered a new generation of power supplies that combine more features than ever before.
The Strider Plus ST50F-P boasts the important features professionals and enthusiasts crave:
• High efficiency: 80 PLUS Bronze level
• Compact size (140mm depth) to fit in nearly any system
• Class-leading powerful single +12V rail with 34A
• Quiet and cool 120mm fan
- 24hour continuous power output with 40 degree operating temperature
- Class-leading single +12V rail with 34A
- Silent running 120mm fan with 18dBA minimum
- PCI-E connectors support
- Active PFC
- Connectors:1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 1 x 8/6-Pin PCIE connector(550mm) / 3 x 6-Pin PCIE connector(550mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 3 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 1 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
- Cooling System: Silent 120mm fan
- Dimensions: 150 mm (W) x 86 mm (H) x 140 mm (D)
- Weight: 1.8 kg
Only £64.99 inc VAT.
ORDER NOW
They are now here
- Active PFC
ORDER NOW
- 1100W peak power
- Active PFC
ORDER NOW
- 80 PLUS Silver
- 950W peak power
- Weight: 2.9 kg
ORDER NOW
- 80 PLUS Silver
- 800W peak power
- Weight: 2.9 kg
ORDER NOW
- 80 PLUS Bronze
- Active PFC
- Weight: 2.9 kg
ORDER NOW
- Active PFC
- Weight: 1.8 kg
ORDER NOW
