your mission - setup for < £400
16 Aug 2006
Stoke
Hi,
I am after a reasonable conroe setup to tide me over for a few months.
I defo want a E6300, not bothered about mobo as long as it offers some general overclocking ability (up to about 2.4ghz), will go with 1gb of ram and upgrade that to faster 2gb ram at later date and also require a reasonable graphics card
Thanks a bunch
Matt
Close...
  • Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard £49.99
  • Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) £71.99
  • Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £105.99
  • BFG GeForce 7300 GT OC 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £48.99
  • Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM £25.99
  • Liteon DVD-8900 16x DVD±RW/RAM (Black) - OEM £15.99
  • Antec NSK4400 Mini Tower Case - 380W SmartPower PSU £42.99
  • Sub Total : £361.93
  • Shipping : £10.95
  • Vat : £65.25
  • Total : £438.13
:cool:
Do all the componants have to be new????
Why not look at some second hand bits on that auction site.
sure you could pick up a better graphics card this way.
Given the requirements are slightly unrealistic I don't think you can do much better than hp7909's specification buying new here. An extra £100 or so on the budget makes such a difference at this level. :)
It does indeed, this is what i specked tho. Again a little bit over!
(£124.54)
(£30.54)
(£58.74)
OcUK 1GB (2x512MB) PC2-6400 800MHz DDR2 Dual Channel Kit
(£75.19)
(£50.51)
(£18.79)
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) -
(£84.59)
Sub Total : £376.93
Total : £455.76
