All of you with SLI systems, what is your prefered rendering mode?
I did afew test earlier and i cant seem to find any differences between them, except for SLI AA.
Test Bed
Athlon 64 X2 4400+ @ FX60
1Gb ram
Asus A8N-SLI SE
7600GT's in SLI with both cards at stock
I know it may vary between games, and that CSS stress test isnt the best benchmark to use but still :
Results
Ran with everything set to high, 4xAA (with SSAA enabled) 16xAF 1280x1024
Just for some sort of comparison between single and SLI, with the one 7600GT i got 85fps in the stress test.
Also to test for any cpu bottlneck i ran the test with no AA/AF - 163fps
SLI Rendering Mode
Auto Select = 131fps
Alternate Frame 1 = 130fps
Alternate Frame 2 = 130fps
Split-Frame = 129fps
Single GPU = 131fps (clearly this option doesnt work)
SLI 4xAA mode = 152fps
SLI 8xAA mode = 90fps
SLI 16xAA mode = 48fps
So as you can see the only major difference is the use of the SLI AA mode, which gave me a big increase in FPS. I will test this mode on other games, but from this test it appears to be the best SLI rendering mode to use
Test Bed
1Gb ram
Asus A8N-SLI SE
Results
SLI Rendering Mode
