Your Score is Low Compared to Similar Systems
8 Mar 2011
My computer specs are
2x Palit Geforce GTX 570, 1280MB, PCI-Express (latest WHQL driver)
Samsung SH-223C bare schwarz SATA
Samsung SpinPoint F3 1000GB, SATA II
Corsair A70 (Sockel AM2/AM2+/AM3/775/1156/1366)
MSI P67A-GD53 (B3), Intel P67, ATX, DDR3
Intel Core i5-2500K Box, LGA1155
Creative Sound Blaster X-Fi Titanium Sound Card
2x Scythe Slip Stream SY1225SL12L - Case fan - 120 mm
Fractal Design Define R3 Series ATX Case - Black Pearl
Corsair CMPSU-750HX Professional Series 750W Power Supply
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Windows 7 64bit
On 3d mark using basic version (free version) I get a score of P9104 3DMarks
3D mark says "Your Score is Low Compared to Similar Systems"
Thoughts on that ?
I suspect it's a SLI problem. Do you have the latest drivers installed?
I don't have any experience with Xfire/SLI but a google search brought up this question on the 3D Mark Q&A
Q: I can’t seem to get SLI working correctly. How do I enable SLI in 3DMark 11?
A: 3DMark 11 automatically takes advantage of multi-GPU configurations (SLI/Crossfire). Note that you need NVIDIA Forceware 266.58 or later drivers for official SLI support in 3DMark 11.
Is your CPU stock? That's probably causing the discrepency as most folk who benchmark are doing so with overclocks - thus inflating the results.
Ditto with the cpu overclock, with a 2500K in particular overclocking is almost standard. Get it running at around 4.5 Ghz and you shouldn't get that.
yap overclocking the cpu has made a "Your Score is Comparable to Similar Systems."
thanks lads for the advice
Im now getting a P9845 3DMarks score
