Your urgent advice please
5 Nov 2006
Hi all,
Was in the process of building a high end socket 2011 system for my Brother in law with a 4930K cpu. I unfortunately previously purchased some 2133Mhz speed Gskill ram quad kit from elsewhere - trouble is it is faulty,so I am going to have to return it.This is a problem,because I was supposed to be delivering the machine between Xmas and new year, but not now. The Gskill ram had nice tight timings of cas 9,11,10,28 - thats why I chose it. So what do I replace it with - if I can order tonight or tomorrow - then there might be a chance of still making my deadline - apart from some other problems.
Any suggestions please?
Mark
what fault? memtest ect
Hi Wazza,
Did not get that far, as I spent a lot of time trying to get them to work.Tried one stick at a time and even mem ok would not boot with them - so gave up and chucked a spare set of two DDR3 Gskill 1600Mghz I had spare, and they worked fine straight away. so it is not the board, but it certainly does not like the ram. Perhaps I could try them tomorrow with memtest, but as 3 out of the four are just not recognised in bios - think I might be wasting my time though.
Your thoughts?
Mark
So with the ram which works have you tried just 1 stick in each ram slot to 100% rule out the mobo??
Must admit I have not done that - I will do tomorrow, groan.
Cheers for the advice though.
Mark
Decided to try the ram in my board and see what happens.
Update: Tried the ram in my system - would not boot at all or even allow me to get in too the bios, so I think deffo faulty. It will have to go back.
Merry Xmas all.
Did you get sorted mark?
As above post - tried them in my machine and absolutely no go - so faulty.Have an rma to return them, and I pick up the same ram set you have later today.Hope this will be the end of my ram problems for this build.
Merry Xmas to you and all;)
Mark
Fitted the new Gskill 2400 kit, and no problems.Have not tweaked it yet,as I have other things to do first. The memory is now spot on though.Thanks all for their help and happy new year to all.
Mark
