- 30 Mar 2007
Hi,
I purchased the Logitech Z5500 a few days ago, and have them connected to an X-Fi via analogue.
The first thing I noticed was a 'buzzing' from the Sub. It's not hugely loud, but I can definitely hear it. Is this correct? I was hoping it would be a bit more silent.
The Sub is only a light Buzz, which I can only hear when I'm laid down on the floor with my ear to it. Am I right in thinking that if some of you Z5500 owners out there did the same, you would hear silence, or do you too hear a slight buzz?
Also, when using the direct connection, I am getting a 'hiss' throughout all the speakers. When I change the effect to 'Stereo', the hiss vanishes, but the hiss returns on all other effects. What is the problem here?
Something else I have noticed, which is a definite fault. When I am playing a song, and if its a particularly intense (I don't know how else to describe it) sound, the back left speaker vibrates like crazy, and I mean vibrates in that I can hear the actual speaker hitting itself. Is there any way to stop this? It's almost like the enclosure isn't tight or something, even though it is.
Any help appreciated,
Simon
Simon
