Z-5500 vs Z-5400
8 Jan 2005
kinlochleven
Hey,
Is there any major difference in the sound quality (or usabilty) between these two Logitech Z-5500 vs Z-5400 5.1 systems?
Big difference in price right enuff but the Z-5500 looks slick as hell!
Also and this will make you wince, but i need to use my old £10 PCworld sound card as it has the old joystick port on it and i can live with out my MS sidewinder joystick so they crap sound card has to stay. Anyway can you connect the Z-5500 or Z-5400 to the regular outputs on a cheap 5.1 card?
Cheers
eurocon
www.ete-clan.com
z5500's are better to be quite honest. They are considerably more powerful, and better looking. Plus the fact that they arn't wirless will probably mean they sound better. In my book wirless is bad, plus the z5500's are cheaper.
The z5400's aren't wireless ;) Plus they're 50-60 quid cheaper.
The Z5450's are the wireless versions.
