Z-5500
29 Jan 2007
Ritefast HQ
Hi there i have these speakers i was wondering is there a way of connecting these to the tele,dvd and playstation as well as the pc? If so what do i need to buy thanks.
Without knowing what audio ports you have on your equipmetn it is a bit hard to tell you what cables you need.
I use a combination of a Optical cable - 1M TOSlink Optical Cable and
3.5mm Jack to 2x Phono Cable
I connect my media centre pc to the speakers over SPDIF using the TOSlink cable and my Wii via the 2.5mm jack.
