So I upgraded to a Z170x Gaming 7, 6600k and some Avexir DDR4 last week, but only managed to get it up and running yesterday because of work.
I've now noticed some very strange activities:
1) Very difficult to install software
2) Start up takes around 30% longer (from 23s to 30s+)
3) Some programs won't start (NZXT CAM will load, but hang on login page)
4) Ridiculous reboot times. Last night I had to just turn the power off (after 10 minutes) and today it knocked off the power to the peripherals in a reasonable time, but then didn't actually reboot.
5) Can't close hanging programs such as CAM once they've frozen, they won't even react to task manager.
I completed a full visual inspection of all the hardware before installing (motherboard was B-grade). Nothing unusual. Computer works fine outside of those applications and will do everything else perfectly.
All updated have been completed, BIOS update, etc....
Just scratching my head at this. The RAM picks up perfectly and I tested it in another computer. I can't really test the CPU and mobo in another computer because the other is under hardline cooling.
