Z170 RAID Q!!
23 Nov 2010
Hey,
I just built a new rig, blindly not looking into M.2!!
I have the Asus Maximus Hero Alpha, it has one native M.2 port, my question is, if I add a PCI-E M.2 card, could I RAID the 2 disks across different controllers?
Any help appreciated.
Regards
Ryan
Only software raid in windows. IIRC
and also if one is in the M.2 slot and another in a PCIe slot they are using the PCIe lanes so they are still on the same controller.
Hey,
Thanks for the reply :)
That makes a lot of sense, after reading up a little, I understand that if you disable CMS and enable RAID, save and exit, the next time you enter UEFI, a new menu for Intel RST is available, can anyone confirm?
Cheers
