Hi guys so since updating my bios a while back I've been working on trying to get my system overclocked again. I'd used the offset method previously but with previous options seemingly missing I've been at a loss. I finally found a guide I was comfortable with.
My settings are:-
Enhanced Multicore Performance - Disabled
CPU Clock Ration - 50
AVX Offset - 0
Intel Turbo Boost Tech - On
Turbo Ratios - All @ 50
Hyper Threading Tech - Enabled
Speed Shift Tech - Disabled
CPU Vcore LLC - Turbo
Cpu Vcore - 1.3
Cinebench R20 shows a near 600 point difference and completes fine.
I am noticing some strange behaviours though, HWinfo seems to show the cores repeatedly jumping between 800Mhz and 5Ghz is this normal? Also if I try to run Prime95 Small FFT's the system instantly hard locks and I get a BSOD.Also getting random BSOD's with the WHEA Uncorrectable Error What can you guys recommend for getting stable?
My settings are:-
AVX Offset - 0
Cpu Vcore - 1.3
