Hi all
First post but long time PC gamer/builder.
Just upgraded from 3770k to 9700K on an Asus TUF Z390 Pro Gaming board.
Case is a BeQuiet Dark Base Pro 900 (huge) and cooling is a new Corsair H105 (240) AIO in push/pull.
Corsair Vengance 3200 DDR4 ram 32GB. (4x8gb)
For whatever reason I'm unable to get the temps down. Idle is fine as in ambient is 25 and the CPU package is 29-32.
As soon as any load is on the CPU, ie Prime95, Cinebench etc it wacks up to 90+. This is with the fans on full speed (manual control
and reapplied MX4 paste. Thermal Throttling occurs and this is at stock speeds! Not even started to try overclocking. Even just light gaming it's hitting 80+
Voltage I've tried Auto, adaptive 1.3 and offset -.09 etc.. with LLC3-6.
I've got direct Molex power to the pump, though I have tried the AIO header on the board too.
The cooler is fitting fine. I've tried the stock paste on the H105, MX4 and IC Graphite Pads. Same results with all of them.
Fans in the case are 3 x 140 intake (2 front 1 under) 4x120 in push / pull on the AIO. (top mounted) and 1 x 120 rear by the gfx. (case is inverted so GPU is above the CPU)
Gfx is a 1070ti Zotac Mini so it can dump heat in the case, though Prime doesn't hit the GPU in these tests.
(I have an H75 and G12 to watercool the gfx soon anyway)
I've disabled the Asus Multicore Enhancement, played around with the core voltage with offsets etc, LLC's and tried even underclocking it to 4.4 turbo, but it still craps out with temps. I've also tried swapping out the RAM and running just 16gb with the same results.
I'm at a loss as to where the problem is. I've updated the BIOS, loaded defaults, turned off turbo etc and still the temps are crazy high. I've read that these chips should be happy enough @ 4.9 on all cores or even 5.0+ with pretty much the same cooling (240) that I have.
Unsure if it's a bad CPU / Solder TIM, crap motherboard or a dodgy cooler.
Will try fitting my H75 on it tomorrow but being smaller I'm not expecting any improvement.
Just wondered if anyone had any other thoughts on this situation before I scream and send all the parts back for RMA.
Thanks in advance
Thanks in advance
