Z5500 Subwoofer next to PC?
26 Aug 2004
Has anyone here tried to place their Z5500 subwoofer right next to their PC's base unit?
My case is made of steel so I was wondering if it should be ok to place my Z5500 subwoofer about 1 foot away from it?
theres a huge notice saying no less than 2 feet away.
When i did, i had radio playing through the sub. So now I've got the sub the other side of the room :)
Hey man lol if ** going to switch on the bass one..it is equipped with a huge magnet so it can interfer with nearby radios and i heard even with the computer cpu (dunno about that tho) and another thing is that you will damage ** computer from the inside lol because a computer isnt some kind of a rally car :D
funny, never had a problem with a sub sitting next to my old htpc. good couple of years it was there. now my £425 worth of ps3 is sitting on top of it. am i mad? time will tell.
they put those warning on there to cover their arses. the magnet on the sub is no worry for a hard drive, hdd's use some of the most powerful magnets in the world. the z5500 uses a plain ferite magnet as far as i know, nowhere near powerful enough to disrupt the drives heads. The amp and electronics are more likely to interfere with a pc.
edit: and it never interfered with my av amp, either.
