Z63 vs BeQuiet DRP
28 Jun 2011
Sorry if this has been brought up before, when I look online all I can find are reports a few years old so wanted to ask opinions here.
I’m debating between using the NZXT Z63 or Dark Rock Pro (BeQuiet just updated compatibility with the Z790 boards).
It’s the first time I’m building with a window and thought the Z63 280mm looked really good. However I really hate noise so also ordered 2 fans to replace the stock ones, now I’m a bit worried about potential noise levels and wondering if I should have gone with the DRP.
Does anyone have any experience with the Z63, it’s to go with a 13700k.
Thank you.
No experience but NXZT comes with cam software so you should be able yo set a custom fan profile.
Drp4 fans can be set in the bios also.
Thank you for the reply, I think I’m just nervous about going with an aio. It was easy last month when I was ordering parts, now it’s coming up to the time to build it, I’m debating if I should have just stuck with air.
Personally I wouldn’t buy any Asetek based AIO. Most will have high pitch noise, some suddenly dying.
For me is either Arctic Freezer II is you like their looks and your case can accommodate the thicker radiator or EK, which has a very good and quiet pump.
For air, either Noctua or BeQuiet.
Thank you Drumroll, I’ve just ordered the dark rock pro 4, I’ve used a few of the 4 version and never had an issue, I think sticking with what I know is the safer option.
