Z68 Extreme4 Gen3 - problems
30 Oct 2011
Birmingham UK
Asrock Z68 Extreme4 Gen3 - problems
I had posted in the topic Z68 Extreme4 Gen3
Code:
http://forums.overclockers.co.uk/showthread.php?t=18296625&page=16
Thought a new topic may be better as I am stuck and do not want to hog a popular topic with my problems
New components from overclockers -
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard
Kingston HyperX Genesis Grey 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Connected it to a Hyper 1000 PSU, 24pin and 8 pin plugged in
CPU cooler on
Not used a GFX card or hard drive yet
Mouse - USB Razer Krait
Keyboard - USB Microsoft natural ergonomic 4000
Keyboard and mouse are recognised in the first boot screen
If it does boot, sometimes I can press the delete key to carry on, then it freezes on the BIOS screen or the mouse will work then freeze
Cleared cmos several times
Tried RAM in different slots
Noticed it hang on these errors 19 and 60, 62
Just managed to press delete on the first screen to go to the bios page and it gave a blank screen with B6 in the corner
Any help will be gratefully recieved
edit - Put stock CPU cooler on, reset cmos, reseated RAM
No keyboard or mouse working, seems a common problem
Getting error 19
edit - looking round the net seems people get problems with the keyboard not recognised
Tried all USB ports
USB to PS2 connector was an idea?
On another PC forum with an ASRock tech help they advise updating the bios, I can not access it
Searching the net it seems a lot of people have this problem with keyboards
I can not access the bios to enable that or make any changes as the keyboard are not recognised
Have a drive connected
SSD is next on my list to buy
Legacy usb 2.0 is enabled by default(I think) so even after a bios clear and plugging the KB to usb 2.0 port it doesn't work, I am out of ideas :( sorry!
I built a system on this board last nite, had issues with devices plugged into the usb3.0 ports until I changed the legacy options in the bios. Used a bog standard dell usb keyboard for the install, didnt have any issues picking it up at all.
Thanks, I will order one of these and hope
NEW DELL USB Keyboard BLACK SLIM UK QWERTY Layout P/N : Y531K
usb to ps2 adaptor is in the post
Just rebuilding my Extreme 4 Gen 3 today & found out it will not work with a PS2 mouse, have four in my spares box & NOT one will work with the board, board won't even boot.:mad:
But, but trying several usb mice, Logitech,Deathadder, etc, the board perfoms flawlessly, loads windows in seconds.
Thanks for telling me, I am awaiting 2 keyboard's to see if it helps
ASRock have yet to reply to me
Do not want to be stuck with a board that will not work
Should the Intel Z68 [V8] be really hot?
i wouldn't be too worried about the southbridge heatsink getting hot, unless its really too hot to touch.
