Z68A GD55(B3) Settings check please
25 Nov 2009
Warrington
Bit of a noob at this so I pulled the settings direct from an issue of CPC, but they were set up for the p67 variant, not the z68. The efi is pretty much the same though so it seemed logical that they were interchangable
It seems to run nice at 4.5Ghz (2500k) and temps peak @ 61 after 90 mins of Prime95 blend.
My only concern is that the VCCIO and VCCSA seem to be a fair bit higher than other settings than Ive looked into for a stable 4.5Ghz OC.
I just dont want to prematurely cripple the CPU or board.
Full specs
2500k + beQuiet dark rock advanced
z68a gd55
4gb (2x2) corsair vengance LP 1600mhz 9-9-9-24
Asus HD 6850 Direct CU
Settings
CPU Ratio- 45
Vdroop - Auto
CPU Vcore - 1.28v
CPU I/O (VCCIO) 1.17v
System agent voltage (VCCSA) 1.185v
PLL overvoltage - Auto
Ram voltage - auto (1.50v)
Thanks in advance
