Z68XP-UD3P Power up issue help
13 Jul 2011
Cheshire
hey
i am in need of some help before i lose the plot. Last couple of weeks my computers is been playing up (see spec below). I have the power issue where i turn it on and then it goes off again does this 2 or 3 times when its being first turned on in the day. I am using the F7 bios just updated from F6 and still doing the same. Some times it boots up and loses my overclock settings but also frezzes and locks up solid just while in windows under no load. When under load for hours its fine but when it frezzes up solid i have to hold the power button down for 3 secs it goes off then when it trys to boot again it trys to boot runs for 3 secs then turns off and carry on doing this till i switch it off at the power supply for more than 5 secs . Any ideas before i rip it out and go haswel ;)
cheers
RMA the board, you have a 3 year warranty.
Is it ok at stock speeds?
If its losing settings then is the battery ok?
