Z77-D3H BIOS problems
6 Dec 2007
Dewsbury
After being advised to flash my BIOS to the latest beta version (F19g/h), I have run into major problems. I reset the CMOS as I read that that can cure the BIOS not reading any keyboard input, but now whenever I start up my PC, I get the 'BIOS has been reset' message, with options of how I want to continue. Unfortunately the CMOS reset hasn't cured the lack of keyboard input, and I've tried the keyboard in every USB port I have.
Where do I go from here? I can't enter BIOS, I can't chose an option for the 'BIOS has been reset' screen. USB mouse isn't working either.
Both are Logitech products (G110 and G500), both worked absolutely fine on the stock BIOS (which came on the mobo from factory). I have the old BIOS saved on a USB, but I won't be able to select the Q-Flash menu to flash that onto the mobo
I know some Gigabyte BIOS version have problems with DVI, but everything seems to work (it went through startup fine before I reset the CMOS, and now I've reset the CMOS, it goes to the option screen fine), apart from a total lack of response from keyboard input.
Help!!
