I've worked it out, can a admin close this please
Thanks!
Well, why not share what you worked out in case others have the same issue
Whats your overclock settings for 4.5ghz?
F8 doesn't work, it opens up ROG boot menu but doesn't allow for safe mode. The only way i figured it would work is to go into msconfig and set safe mode there then restart. After you've done what you needed to do go back into msconfig and disable safe mode and restart to get back into normal windows mode
Nice! what are your voltages like?
I'm currently using the same board as you but sat at 4.6ghz using manual voltage.
The BIOS gives CPU 1.320, never crash's in anything I do so I am happy with that and no real need to tinker, why fix what ain't broken
What volts you got for 4.6?
I had it at 4.6 on 1.320v for 2 weeks, it blue screened on me so I just dropped back to 4.5, 4.5 seems to be the sweet spot for temps with ivy unless you get into delidding, to which I cannot afford to do
