Z77 MITX help please
1 Dec 2005
Stoke on Trent
Can you help me to get 4Ghz out of my 2500K on a Z77N-Wifi MITX board.
Ran fine at 4Ghz on stock volts in my P67 board. Just not sure what options to change in the new gigabyte bios.
Also im trying to run my memory at its rated 1600Mhz @ 1.5v, but when I think ive set it to 1600Mhz in the bios it fails to boot. Again I know it will do its stock speeds as it did it in the P67 board. The meory is Geil Black Dragon 16Gb Kit and its the 1600Mhz kit.
Any help appreciated :)
I dont have that board in the office to test with mate. The figures your looking for should be easy though. Very easy!!!
I will see if I can test this for you though in tech but not sure I can churn it out before I go to Computex at weekend.
Could you post up some Bios screen shots and I will advice from there.
