Z77 PCIE 60c warning AI SUITE II
14 May 2012
Is this a problem? Or should I just leave it I have never seen PCI slots temps being monitored before, but when I play any game for over 20 mins I always get 60c warning in AI Suite, I dont think it ever goes over 60c
I have 6870 CF, In a HAF X case with plenty of fans my gpu`s dont exceed 80c on high loads for example furmark
I would take it as a pinch of salt tbh... the software on the Asus X79/77 boards seem to give of dodgy indications. For example my 3770K sometimes does 4.4GHz on only 0.03v and at load is only -22 degrees! :eek:
Agree, the AISuite goes a bit crazy sometimes. Make sure you have the latest version. I use it to keep an eye on the CPU VCORE (MOSFET) temps
It shows the essential ones though. AiSuite is very buggy and the warnings are annoying.
Turbo V is good and Digi Pwr thats all I use.
