Z77E ITX asrock problems
31 Jul 2011
Hi,
I've having major problems with my board. I've done several clean installs of windows + drivers to check I haven't gone mad.
1) The Ethernet (LAN) is not listed in the device manager, and is listed as unplugged in BIOS. Nothing will fix this - from Cmos reset, to reinstalling drivers etc.
2) The wireless card is not recognised. As far as Bios is concerned there is nothing plugged into the mini pci slot. Needless to say windows doesn't recognise it.
3) USB is broken. The sockets are functional (both from and back) - I could tell by plugging my e-cig into the socket and the charging light working. However, device manager lists - Intel (R) USB 3.0 eXtensible Host Controller with an !. This is the least broken part, as at least it is recognised. The properties screen say this device cannot start. (Code 10). This happens regardless of drivers.
I have tried nearly every combination of Bios and countless OS installs and driver installs. Can you tell me if I'm missing anything?
I presume the board is faulty, but I want to check I haven't missed anything.
Thanks.
