Z77X-D3H - Weird problem
24 Jun 2008
Droitwich
Just wondering if anyone was come across this before..
I have been using a tv as my only screen now for a few years and this graphics card with it for ~6 months with no issues..
I recently upgraded motherboard/proc/ram and straight away i was having issues with it booting up.
Only part of the post screen will display on my tv... i cant enter the bios and cant load past there..
After lots of the usual checking i tried a different monitor.. the bios shos up fine there and loads up no problem.
I can use the computer fine as long as the TV isnt the only screen.. it will just keep trying to post until a different monitor is plugged in /the tv is unplugged.
I previously was connecting with a dvi-hdmi cable but i have even tried with a hdmi-hdmi and im still having no luck.
Has anyone come across a similar issue before? Everything else seems fine just frustrating that i need a different screen to work with the set up..
I have been using the tv now for a few days without any issues.. just with the other monitor as the second display.
Any suggestions would be great
