Z77X-UD3H driver questions
18 May 2010
London
Just bought a new Gigabyte Z77X-UD3H
Have just been looking at the driver section on the Gigabyte website.
1. Under Chipset, what is Intel Management Engine Interface?
2. I see at least 4 different sata drivers which I could potentially use during install of the os. Is it Marvell or Intel? :confused:
3. USB 3 also has two different drivers :confused:
its because there is a marvel chip and a intel (z77) sata on the motherboard
same with the usb (VIA chip and intel z77)
as for Intel Management Engine Interface?
Provides thermal management for Intel® Desktop Boards. The Intel® Management Engine Interface (Intel® ME Interface) is the interface between the Intel® Management Engine firmware and the host. Drivers and applications on the host that wish to interact with Intel® Management Engine through host interface would use the Intel® ME Interface host windows driver.
yeah i didnt understand that eaither just instal it :P
Ok so I have to install all the drivers?
But when Im installing the os, which driver am I going to need for the sata?
Will it depend on which port the ssd is plug in to?
I got the Z77x-UDH3 and when i was trying to install Windows 7 from my memory stick it was asking for a CDROM/DVD driver i presumed it was the sata drivers but it wasnt and wouldnt allow me to install Windows. Turned out the USB pen drive with Windows 7 on has to be plugged into a USB 2 port rather than a USB 3 port
Did you install all the drivers from the website?
How do I know which AHCI driver to give it when there are two?
