Trying to work out the best way to setup offsets and lower Vcore at idle.
Currently running at 4.3ghz more or less auto except for ram at 1866mhz.
Vcore on auto is 1.164v under stress with temps low to mid 60`s but if i try 4.4ghz auto boosts the vcore way too much around 1.35v and temps suffer obviously.
I can run 4.5ghz at 1.26v with LLC at medium but would like lower volts clocks at idle etc.
Not used to the offsets and the way the i5`s run, can anyone explain how to get say 4.5ghz @1.26v but make it down clock volts at idle like setting auto does.
Thanks.
Thanks.
