Z77X-UD5H mSATA question.
4 Nov 2003
Ashford
Hi I have the above board and a 30gbOCZ mSATA card fitted. I want to use this with my 150gb Velociraptor to speed it up with Intel Smart Response. I've been reading the manual but am a little confused so wanted to clear it up before I fit the processor and install windows in the next week or two.
The manual says I will loose SATA port 5 with the mSATA card installed and the instructions for Smart Response say to set "RAID enabled for the Intel SATA controllers in BIOS" does this mean the Raptor has to be on the same controller as 5 (i.e. 1-4) and do I need to set the two up as a raid array or is the fact raid is set to on enough to install windows?
Thanks for nay help clearing this up for me.
