Hi all,
Was messing around with my clock settings last night after running some benchmarks - I just tried the overclock profile option available in BIOS (20% updagrade) which bumps me up to 4.3Ghz (not sure what memory speed) but after running the benchmark again, it doesn't actually bump the speed up either on idle or under load - 3Dmark reported max turbo clock as 3.4 which is standard. So I tried going manually and upping the CPU base clock, leaving multiplier and voltage standard, and then upped the memory from 1600 to 2000, it automatically upped the voltage to 1.65v from 1.5v I think. It wouldn't boot properly after that - would just hang, so I made sure to put the memory back to normal as I didn't want to alter voltages in the first place. Still no boot. Reset BIOS to default and now when it starts it will always ask if I want to go into startup repair or launch normally. If i launch normally, the Win7 logo animation will start for half a second and then all USB devices go off, and then BSOD saying it's been shut down to prevent damage with STOP code 0x000007B - apparently that means innaccesible boot device!? Startup repair just fails and says it couldn't finish. Any ideas? I've tried swapping SATA port on main HDD and only having that plugged in but exactly the same...
