- 13 May 2015
In need of help with manual overclocking with the following components as i tried the easy way by using easytune and let it auto overclock which the software did at 4.2 ghz but it would freeze a lot.
In the bios i see there is no profile for my memory so it is disabled.
At the minute i am using the easytune software with the cpu at 3.6 ghz but would like to config through the bios with a rock solid overclock of 4.2 ghz+
CPU - G3258
MB - Z97P-D3
Memory - 16GB HyperX Fury 1866 CL10
Cooler - Hyper 212 EVO
GPU - GTX 550 TI 1GB [ i know the gpu is old and slow but will do in the mean time]
CPU - G3258
MB - Z97P-D3
