Hiya guys
Having some major issues here considering to do a rma on the mobo.
I can't get the mobo to boot up into the bios or even windows sometimes it will actually happen but might possibly freeze then ill have to restart the pc then that's not even a 100% chance of it booting at all.
I have noticed the LED Number flash thingy Sometimes won;t come one showing no Error codes or such when this happens the mobo won;t boot at all. Everything seems to be spinning checked all the cables etc and still no luck. When this happens there's no signal to the monitor.
Even resetted the bios with the switch and even tried doing it via leaving the battery out for 30 minutes still no luck.
Pc has been working fine for the past week without any issues but last night i was playing War Thunder and the pc crashed No Bsod or anything just instantly shut off. then the issues started to happen.
Kinda Stumped as to what to do.
I assume it wouldn't be a issue with the cpu overheating otherwise the pc would just instantly turn off if that was the case.
Karl
Karl
