Since I installed the latest ZA freeware update I've been having weird connection problems. Basically sometimes when I start my computers ZA is blocking everything. I turn ZA off and everything connects fine. Then I turn ZA back on and most of the time, all the connections continue to work fine. If it was a config problem with ZA I would have assumed the problem would remain even after turning ZA off then back one again.
PC is wired to a wireless router, the laptop is well, wireless. The wireless router sits behind a ATA/Router. Not that I think the problem is with the hardware, since it all works once ZA is turned off.
I'm baffled. Reinstalling ZA afresh didn't fix the problem. The problem happens on both machines.
