zalman 9700 led
17 Jul 2008
Does anbody have one of these on a dfi lanparty nf4 sli expert board.
Need to know if it clears ram in orange slots, would like to upgrade from artic cooler freezer 64 pro to the zalman for lower temps/more overclocking headroom.
I had a 9700 on my last pc but not the same board and i was worried about the same thing. The heat pipes at the bottom suspended the heatsink well above any other components on the board. Looking at that dfi board the ram slots are close, I think you should be fine but you may have to install your ram before you mount the 9700 i will over hang slightly. The dimensions of it can be found in the manual http://www.zalman.co.kr/ENG/product/Product_Read.asp?Idx=164
