Zalman 9700, tips? and best compound?
13 Feb 2006
UK
Hi,
just about to fit a 9700 to my E6600 & 680i.
which compund should i use, the included or some AS5?
also, do you think i will be able to slide the backplate down or will i have to remove the mobo ?
I tried sliding the backplate down my 680i, sadly it is impossible and you have to remove the mobo to fit the back plate and mounting bracket.
use as5.
