Zalman AM2 Retention Clip
1 Apr 2009
Hello Folks.
I have lost the little right-angled clip that comes with the Zalman AM2 retention bracket. Does anyone know where I may be able to find one.
Cheers
I seem to have found the full retention thing (Possibly, although it says its for the water block)
Just type "Zalman ZM-OC2 AM2 clip for ZM-WB4 water block" into google, theres a few places. If its just the small clip at the end then theres no worries.
Im pretty sure its what you want. Only reason is because im using the zalman 9500 on an am3 board so I just had a peek to compare in my case xD
Oh and if you get it from the place with a 'special' name then make sure you change the postage type so itll cost £3.5 instead of £9.50.
