Can anyone confirm that I have received the incorrect clips for this unit?
The box states that the cooler fits an AM3+ motherboard. The AMD clips supplied are completely straight and rigid and there is a unreasonable gap between them and the backplate. I am convinced that screwing these down properly (if that's even possible) will damage the CPU and motherboard. The clips differ from the ones illustrated in the manual (link below) as well as ones I have previously seen for AMD motherboards.
Image of clip. Clip to its left is the Intel one, for comparison.
Image of illustrated AMD clip in manual. The ones supplied have no kink in the ends and therefore do not allow the bolts to get close enough to the nuts attached to the backplate.
