Zalman CNPS10X-Quiet
15 Nov 2008
Scotland / Blairgowrie
Got this for my core i5. bought this over the extreme because in reviews it said paying £10 more for the extreme was a waste. Only 1C difference overclocked and at full load.
I was wondering , could i buy a fan for it? I don't really mind if its quiet, my pc is packed away under me, you cant even hear the noisey case and power supply fans.
the fan noise is 26 dB full load, 1400RPM max speed, and i don't have a clue about the CFM.
What fan do you recommend replacing the stock fan with ? more cfm the better. Must be 120mm (12cm), quiet with blue LED if possible.
Please dont recommend me the delta foccused fan. I put one on my old case and WOW that was loud. If i was deaf i wouldn't mind replacing all 5 fans in my pc with it tbh.
