I've just tested the Freezer 64 with a 64-bit Sempron 2800+ and I'm impressed. It's fan is running at ~2400 RPM (very quiet to my ears) and the 2800+ is at 2.4Ghz (8 x 300) with 1.54v. Not that it needs such a high vcore as it can do that speed on default volts but I wanted to create as much heat as possible.
I'm currently using BIOS 1.5 on my Neo Platinum which maxes out the vcore at 1.54v although I can get 1.6v by using BIOS 2.1. I switched to 1.5 just to see if I had any extra options because I knew it wouldn't be able to recognise this E6 sempron but alas the default vcore option isn't available like it is when I use a mobile AMD 64 CPU (would have allowed me to use 1.65v and hopefully get 3Ghz stable). It's weird with the 2.1BIOS as the vcore adjustments are backwards so +10% = +3.3%, +8.3% = 5% etc.
Here's a breakdown of the temperatures:
Idle:
CPU: 29c
NB: 27c
AUX: 26c
HD: 23c
I replaced the heatsink on the NB hence why I get such a good NB temperature.
Max load:
I run 2 x Prime95 on priority 1(1 doing small FFTs and the other doing in-place large FFTs) and S&M CPU (FPU) on 100% load.
CPU: 45c to 49c (fluctuates probably because the stress created by S&M changes)
NB: 27c
AUX: 27c
HD: 23c
I have the Freezer 64 pointing directly at the PSU fan (I'm using an Enermax 285w SFX PSU in a Antec Lanboy case) so the hot air from the CPU is being removed instantly and as you can see from the other temps it's working really well! The PSU fan is temperature controlled and goes from ~1400 RPM to ~2200 RPM quite quickly.
What's even more surprising about the Freezer 64 performance is the CPU drops almost instantly to idle temperature when I stop the Prime95s and S&M.
Also room temperature is probably around 18c or so as I don't have any heating on and the window is open although it doesn't feel very cold and I'm only wearing a t-shirt.
By comparison in the same case with same everything but using a 3400+ DTR with a SLK-948U and 92mm fan on high speed (noisy) with the 3400+ at 2.4Ghz (8 x 300 again) but with 1.63v the system freezes up requiring a reboot after about 20 mins of the above max load testing. Reason appears to be because the CPU temperature goes beyond 65c so I suspect the CPU just can't handle such heat and obviously the SLK-948U isn't up to the task of dissipating the heat fast enough to keep the temperatures low enough for it to be stable. Also the other temperatures go quite a bit higher and no doubt it's because the fan on the SLK-948U is blowing down onto the heatsink compared to the Freezer 64 which blows sideways into the heatsink.
Also for comparison the CPU at default vcore (1.4v) and 2.4 Ghz (8 x 300) the max temperature is only 33c to 38c when running it at max load.
So yeah this Freezer 64 is incredibly efficient but saying that I can't see it being able to cool a CPU running at 1.6v+ below 60c so I guess I will have to try the Thermaltake Big Typhoon to see if it can do it and maybe also try the Zalman.
I guess it's possible that none of the air coolers will cool a CPU with 1.6v well enough at max load and is probably why a lot of people using air cooling on here tend not to go beyond 1.55v.
I type too much don't I?
