Zalman CNPS9500-Cu LED
well the coolers that are mention are currently the best on the market either the zalman or the scythe ninja are good what your system specs
I have that cooler and I think it's excellent! Highly recommend it.
I have a X2 3800+ clocked to 2500MHz @ 1.4V and it cools it nicely - 30C idle and about 38/39C fully loaded.
i personaly dont have the cooler but if you check on the zalman website it does fit all intel sockets and the review that you posted from Xbit labs will tell you that it is a very good cooler which tou can see from the graphs
http://www.zalman.co.kr/
click this link then intel CPUs on the left then the CNPS9500 LED it also shows you how to install it onto your motherboard
as far as i know you should be able to get 3.4-3.6 maybee if your mobo will take it without reaching 55 althogh i am not very familiar with intel CPUs
nick, my P4 idles at 45C with an Evo 33. and gets to 3.2 at 60C load. And it is the same processor (socket, core and speed) so the EVo 33 is good. But i dont think it will do beyond 3.2. I going to try it tho.
