Zalman CNPS9500 LED Question
13 Dec 2005
uk
hi
just replaced my Zalman 7000B with CNPS9500 LED + Arctic Silver 5 on Asus P4C800-E Deluxe socket 478
i can see 2-3 *C temp drop with only 1350rpm versa 7000B some 2000rpm
which is good i think
once installed i can move whole cooler few degrees clock and anti-clockwise direction is not so stiff like 7000B where u can't move it at all
is this normal ?
Asked the exact same question when i got mine, everyone replied with the same answer, which was a big fat yes :D
thanks dude i was beginning to worry :rolleyes:
and probably is possible to turn plastic socket on mobo so the zalman's fitting clip will run thru heatpipes
oh well to lazy to try this time :)
I wish you all "stay cool "
