Gashman said:does watercooling in a everyday sort of situation offer any better cooling than a zalman CNPS9500 at all?
Not all beat a Zalman but most reasonable sets do, what you need to remember is to get at least a 120mm radiator and a reasonable pump.Minstadave said:http://xbitlabs.com/articles/coolers/display/16watercooling.html
Here's a review of 16 watercooling kits against the Zalman CNPS 9500, nearly every one beats it iirc.
Dutch Guy said:Not all beat a Zalman but most reasonable sets do, what you need to remember is to get at least a 120mm radiator and a reasonable pump.
IamMed said:erm, u meen gallons per hour?
60 litres an hour is seriously weak
the eheim 1048 is regarded as a low flow pump and that does 600litres per hour
Very bad set, has a pump that pumps 27 liters per hour: http://xbitlabs.com/articles/coolers/display/16watercooling_24.htmlIamMed said:erm, u meen gallons per hour?
