Zalman CNPS9700NT vs ThermalRight Ultra 120
21 Aug 2007
Ok, so currently I have a Zalman CNPS 9700NT cooler which is currently looking after my Q6600 G0 @ 3Ghz. Idle temps are between 25C and 35C dependant on room conditions and whether speed step is active. Load temps with 4 cores running prime95 small ftt test are around 46C-50C.
Do you think I would see a reasonable amount of difference with the Thermalright + 120mm fan to justify spending £70 Inc Delivery?
Also does anyone know if the Thermaltake armor with 25cm side fan will fit this cooler?
Thanks.
Thanks.
No.
