- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Zalman CNPS9900-MAX Blue LED CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £42.99 inc VAT
Optimally designed pure copper fins effectively disperse heat away from the CPU via composite heatpipes, while the high capacity 135mm fan quickly cools the heatsink for stable operation of high performance CPUs. CNPS9900 MAX utilizes Composite heatpipe which is 50% more effective in transferring heat compared to ordinary heatpipes. An ultra quiet 135mm fan is incorporated for minimized noise. The entire copper heatsink of CNPS9900 MAX is ‘Black-Pearl’ Nickel Plated for long-term corrosion resistance, while the deep ‘Black-Pearl’ tone along with the high intensity Blue / Red LEDs reinforce its powerful aesthetics.
- Dimensions: 94(L) x 131(W) x 152(H)mm
- Weight: 755g
- Materials: Pure Copper/Black-Pearl Nickel Plated
- Dissipation Area: 5.4cm
- PWM Fan Controlller
- Fan Bearing: Long life bearing
- Fan RPM: 900 - 1900
- Fan Noise: 18 - 30dBA
- 300w Cooling Performance
- Includes ZM-STG2 Thermal Grease
Only £42.99 inc VAT.
ORDER NOW
Zalman CNPS9900-MAX Red LED CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £42.99 inc VAT
- Weight: 755g
ORDER NOW
- Weight: 755g
ORDER NOW
- Weight: 755g
ORDER NOW
