Zalman Compatibility
23 Feb 2003
Newport - S Wales
Hi all,
I’m just about to purchase the Abit Fatal1ty M/B to replace my old NFS7 V2. I’m currently running a Zalman Cooling tower with the VGA/CPU block, and I need to know if they will be compatible with the new CPU. (It’s a Core 2 Duo E6400) Will I need to replace the block, or will I need to get new fixtures as its currently fitted to a Athlon XP CPU.
Also, is it worthwhile to get a Northbridge cooler with this M/B as well?
Thanks
