Zalman Fan Bracket
9 May 2007
Hi
can someone tell do i have to have the fanfix1 screw to mount fans or would normal fan screws be alright. also has anyone got any actual pictures of these in use??
Which Zalman, I have a CNPS9500-AT Aero Flower. All screws were supplied and it fitted no problem (was very tight though to be honest, put a lot of pressure on it trying to get it fitted).
You should be able use either though the knurled screw is easier to tweak once attached.
I bought the bracket from here a while ago and it did come complete with the knurled screw.
