You don't want one, very well made PC7 would be the best way to describe it. But they're hugely expensive with no stand out features and the branding completely ruins the look.
WHAT !?
PC7?
GT1000's are way way above the quality of any Lian Li case... there is just no comparison to be honest.
If any of you actually see, or use this case in the flesh it will not be long before you see where the money goes.
they are expensive but I am yet to see a better built, nicer looking case.
Stand out features would be the GENIUS hard drive cage, it is the only tool-less cage I've used that 'works' and works well.
DVD / CD installation is a doddle with, again some of the best 'tool-less' fittings i have used.
removable main board tray
solid, thick aluminium case that will exceed any expectations of quality.
They will fit a 8800GTX / ultra, but if you plan on putting 2 in, I would advise putting a 92mm fan in the window of the case.
Rb
