Zalman Headphones
10 Jan 2007
Warwickshire
i currently have a set of these, the 1st set they chruned out, ive been really impressed with them and thought they worked well,,, unfortuently they r about to give up on me, so im looking for some new headphones, they will be used for games and film watching mostly
i was thinking of buying the nxt version up to these, does any one have them, any one recomend them??
or some thing else? i have a £50ish budget for a new set
Thanks Mike
Are you wanting a headset with microphone or just headphones?
If it's just headphones and you can use open backed then i can fully recommend the Sennheiser HD555's.
Seem to come in at around £50. Took me a while researching until i found these. Sound great and importantly are incredibly comfortable over extended periods of use.
gt
gt
I have a pair of HD555's as well and I would really recommend them. Great for music/movies/gaming.
Get them, you won't be dissappointed :p
£50 is definitely HD555 territory. Good cans, had them for a short period of time before my lovverly audio technicas.
