Zalman LQ1000 problems
22 Sep 2007
Abingdon
I was researching getting this Zalman LQ1000 and found this post on another site:
Zalman LQ1000 Z-Machine - Motherboard alignment problem
I purchased the Zalman LQ1000 Z-Machine from ***** in September.
During my install I had real problems with the motherboard plate mounting holes and my Asus P5Q Pro motherboard. The motherboard ports were out of alignment with the motherboard ports cover plate and the PCI Express / PCI cards with the respective case slots. I had to bend, twist and force the PCI Express/PCI cards into place. At the time I thought this might be a problem with the new motherboard as it was hard to believe a £400 case would have misaligned motherboard plate mounting holes.
However I have now read a review of the LQ1000 at the well regarded Toms Hardware site which states they had the same problem (two Zalman LQ1000 cases tried) and suggests this might be a manufacturing design fault. Details on this page towards the bottom:
http://www.tomshardware.co.uk/Swifte...w-31373-5.html
I have now tried a different motherboard in the Zalman LQ1000 case (aligned fine in an older case) and it also has misalignment problems.
At £400 I am expecting this case to last for quite a few years and don't want to be bending, twisting and forcing the PCI Express/PCI cards into place everytime I change a card as eventually something will break! Also with the current motherboard ports barely lining up with the motherboard ports cover plate as they are too high, I am concerned when I next upgrade my motherboard it may not be possible to force everything to fit at all.
What can be done to fix this under warranty? I believe the aluminium motherboard plate does completely slide out from the case, so one solution would be a swap out for one with correctly aligned holes. At the moment I have not found a way to discuss this with Zalman. I have tried to contact them via the web form on the page below twice in September but received no response at all.
http://www.zalman.co.kr/ENG/Contact/...Write_Form.asp
Many thanks in anticipation of your help.
Needless to say this put me right off and am looking at at TJ09/10 instead.
Just a heads up to those thinking of getting the LQ1000
Is the back tray of the GT1000 different to the tray of the LQ1000? (The GT1000 is just a solid sheet of aluminium). You could possibly try to get a hold of the tray from a GT1000 although that would involve going through Zalman anyway.
