Zalman Reserator 1plus - How to dismantle ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
I realise the Reserator is an F word to perfomance water coolers.
Had a custom built loop before but wanted silence and picked this up cheap on "auction bay".
I've read that you can fit an extended tube to the water inlet to take the incoming heated water nearer the top of the reserator ( seems logical , as i had an XSPC passive res that did the same).
Simply question , how the ****** hell do you take the base off it ?
I've tried twisting/turning but it won't budge and there are no visible screws etc.
It must be removable or you would need 3 foot long fingers to change the pump !
Any Res owners out there willing to share some wisdom ?
Thanks, as always.
Mark
Hi Mark
turn it upside down and the base will unsrew normal anticlock ways turn (mine was very tight :) )
dont have scanner hooked up or would scan the manual.
hope this helps
Steve
00NukE said:
Hi Mark
hope this helps
Steve
Thanks Steve.
Just found the manual on the Zalman site ( why didn't I look there first ? :o )
Now i know it does unscrew , i'll give it some welly !!
Did you tube mod the inlet ?
Thanks for the help.
Mark
