** Zalman Reserator 3 MAX Liquid CPU Cooler **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
The legendary reserator is back on the scene and we have stock landing soon.
reserator3-1-large.jpg~original
Gallery:
WASE_194_1g.jpg~original
WASE_194_4g.jpg~original
WASE_194_2g.jpg~original
WASE_194_7g.jpg~original
WASE_194_3g.jpg~original
WASE_194_5g.jpg~original
WASE_194_9g.jpg~original
Zalman Reserator 3 MAX Liquid CPU Cooler @ £84.98 inc VAT
Zalman improve on the legendary Reserator name and return with the Reserator 3 MAX Liquid CPU Cooler. The world first in nanofluids refrigerant applied cooling.
Features:
- The World's first nanofluids applied cooler
- Optimized dual radial radiator design
- High efficient Quadro cooling path
- Micro-fin copper base applied for quick heat transfer
- Efficient VRM cooling
- Low noise / high performance built-in water pump
- Blue LED applied fan and water block
- Dual fan configuration
- Easy installation and maintenance
Specifications:
- CPU Waterblock: Copper Micro Fin
- Radiator: 1 x 120mm
- Radiator Dimensions: 120mm x 145mm x 79mm
- Fan: 1 x 120mm Blue LED Fan
- Fan Connection: 4 Pin PWM
- Fan Noise: 18.9 to 36.7 dBA
- Special Features: Nano Fluid Cooler
- Dual Radiator Design for 120mm Fan Mount
- Package Contents: 1 x Zalman LCS Cooler, Intel and AMD Mounting Plate, Mounting Screws
Only £84.98 inc VAT.
ORDER NOW
Quite the looker! Seems odd using a circular block though, most of my CPUs have been squarish.
(plus I suspect the 'dead zone' highlighted in their chart would still provide some heat dissipation and if you're not using it for anything else then why not?)
All that said... It is still very tempting!
Looks great, needs some tests!
Mind you it can cool 400W! It'll keep the whole room cool! Marketing idiots!
Not even 8 pack's 4770K puts out 400W of heat!
