** Zalman Reserator 3 MAX Liquid CPU Cooler **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
The legendary reserator is back on the scene and we have stock landing soon.
reserator3-1-large.jpg~original
Gallery:
WASE_194_1g.jpg~original
WASE_194_4g.jpg~original
WASE_194_2g.jpg~original
WASE_194_7g.jpg~original
WASE_194_3g.jpg~original
WASE_194_5g.jpg~original
WASE_194_9g.jpg~original
Zalman Reserator 3 MAX Liquid CPU Cooler @ £84.98 inc VAT
Zalman improve on the legendary Reserator name and return with the Reserator 3 MAX Liquid CPU Cooler. The world first in nanofluids refrigerant applied cooling.
Features:
- The World's first nanofluids applied cooler
- Optimized dual radial radiator design
- High efficient Quadro cooling path
- Micro-fin copper base applied for quick heat transfer
- Efficient VRM cooling
- Low noise / high performance built-in water pump
- Blue LED applied fan and water block
- Dual fan configuration
- Easy installation and maintenance
Specifications:
- CPU Waterblock: Copper Micro Fin
- Radiator: 1 x 120mm
- Radiator Dimensions: 120mm x 145mm x 79mm
- Fan: 1 x 120mm Blue LED Fan
- Fan Connection: 4 Pin PWM
- Fan Noise: 18.9 to 36.7 dBA
- Special Features: Nano Fluid Cooler
- Dual Radiator Design for 120mm Fan Mount
- Package Contents: 1 x Zalman LCS Cooler, Intel and AMD Mounting Plate, Mounting Screws
Only £84.98 inc VAT.
ORDER NOW
I have a lot of love for Zalman for all the innovation they put forward last decade - I still have an Athlon XP PC running one of their copper flower coolers with the fan on a separate arm (CNPS6000?).
Good to see the "flower" style still going strong. Shame about the cheapo blue lights, though.
This could have been so good if they'd made it much taller/longer, there's a good few cases where it could have run nearly the length of a case then been exhausted from a reversed front fan, or stuck to the bottom and run the entire height to a top exhaust...keeping the fan and pump well inside the case and masking the noise.
I really don't get this one at all. Reserators from what I recall are the big external fanless water cooling things from them, sucky performance but silent. I don't really get it being marketed under the same name when it's internal, tiny, pointless and has a fan.
Either way, on top of that, they've seemingly taken one of their round heatsink with fan designs attached some water, a block and a pump then moved the round heatsink from the cpu socket to the rear fan holder....
For me I also don't think it looks fantastic, the actual sink is half hidden by the cheap black plastic holder and a fan.
The general principle of water cooling is to use a bigger radiator/heatsink than is possible directly on the socket by using water to transfer the heat somewhere you can get more cooling.
A small heat sink fan + water makes utterly no sense, you're adding more things to fail, water(I've personally had a Antec version fail) for 2-3 times the cost with zero benefit. At least if you go from a truly giant heatsink to a similar sized radiator but it's a difficult to install due to size heatsink and a say Corsair H-whatever number is easier to install... but they've made a shiny version of the stock intel coolers IMHO and added water to the equation then want about 20 times what a stock intel cooler requires.
So, marketing under a product that stood for everything this isn't, massively overcharging for a tiny "radiator" which is much more like a heatpipe heatsink in reality, throwing water into the mix for no reason... covering the shiny radiator with plastic.....
yes, that's why i think it could have been good if they'd made it much taller...i'll be interested to see the first pc case design that borrows from Apples new Mac Pro cooler system.
