** Zalman Reserator 3 MAX Liquid CPU Cooler **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
The legendary reserator is back on the scene and we have stock landing soon.
reserator3-1-large.jpg~original
Gallery:
WASE_194_1g.jpg~original
WASE_194_4g.jpg~original
WASE_194_2g.jpg~original
WASE_194_7g.jpg~original
WASE_194_3g.jpg~original
WASE_194_5g.jpg~original
WASE_194_9g.jpg~original
Zalman Reserator 3 MAX Liquid CPU Cooler @ £84.98 inc VAT
Zalman improve on the legendary Reserator name and return with the Reserator 3 MAX Liquid CPU Cooler. The world first in nanofluids refrigerant applied cooling.
Features:
- The World's first nanofluids applied cooler
- Optimized dual radial radiator design
- High efficient Quadro cooling path
- Micro-fin copper base applied for quick heat transfer
- Efficient VRM cooling
- Low noise / high performance built-in water pump
- Blue LED applied fan and water block
- Dual fan configuration
- Easy installation and maintenance
Specifications:
- CPU Waterblock: Copper Micro Fin
- Radiator: 1 x 120mm
- Radiator Dimensions: 120mm x 145mm x 79mm
- Fan: 1 x 120mm Blue LED Fan
- Fan Connection: 4 Pin PWM
- Fan Noise: 18.9 to 36.7 dBA
- Special Features: Nano Fluid Cooler
- Dual Radiator Design for 120mm Fan Mount
- Package Contents: 1 x Zalman LCS Cooler, Intel and AMD Mounting Plate, Mounting Screws
Only £84.98 inc VAT.
ORDER NOW
If it's anything like zalman's other coolers it's going to be built like a tank! If I didn't have custom water, i'd be seriously considering one of these.
As there were no pictures of it on a board, this is what it looks like
I'd certainly buy one if my i5 2500k actually needed extra cooling to get it beyond 4.6ghz :p
